My '92 b17 has CTR cams and I’m wondering what specs I should use for a valve adjustment. I believe I need to use the CTR specs, but want to make sure before pulling everything apart.
iirc they are the same. i used the b17 valve lash when i was running my ctrs.
yea the valve clearance still needs to be spec for that motor, regardless of the camshafts. u’re just adjusting the clearance to the position of the camshaft.
so if its like 0.005" for ur stock b17… then still put 0.005" of valve clearance to that camshaft in ur b17.
