Ok I have been at this now for 2 days, I cannot get my remote starter to install on my car. Its a Autostart Prostarter model 3160M Manualm Transmission starter, I have this connected:
Sarter wires → In Car Wires
5 pin harness
Red (x2) - 12V+ → White/black 12V in car
Yellow - Ignition out → Black/yellow in car
Violet - Starter out → black/white in car
Orange - acc. → Yellow in car
7-pin Harness (Dont use 1 pin due to Gluw-plug out)
Black - Ground → Good ground in car
Violet - Tach → blue/white wire in car running up inside the dash (its good used a tach tester on it)
Grey - Hood pin → under hood
Orange - Break switch → Green/white in car
Red - Valet switch - Attached to one of the 2 wires on the on/off switch for the starter
Yellow - Parking Lights → plug @ parking light switch in car
10 pin harness (only 8 used, dont use external trigger or ream pins)
Orange - Dome light in(+) Connect to dome lght wire that has +12V with the doors open–> Not hooked up
Grey - Dome Light in(-) Connect to dome lght wire that has GROUND with the doors open–> Not hooked up
Green w. Black - Ground out Negative output while running–> Coloured wire of clutch switch
white/yellow - Starter killout - Not hooked up
Blue - Parking break → Wired directly into the switch @ parking break
Brown - Lock(-) → Not hooked up no power locks
Green - Unlock(-) → same as above
Blue - Trunk out(-) → not hooked up manual trun relase
With this hooked up I cannot get the car to start, all the starter does is flash one long flash of the parking lights (normal) and then one quick one after then nothing happens. Even if i just bypass the clutch by jumping the 2 wires together on the switch it does the same, I even did the relay trick by how the starter said (87 - one line of the clutch switch, 86 - starter wire, 30 - other wire on clutch switch, 85 - negative output when running on the R/S)
Now the only thing that I can see not allowing the starter to start the car is not having the dome light hooked up thus its thinking that the doors are open? Or maybe not having the starter kill? Why wopuld that need to be hooked up? I attempted to hook up the dome light wire but I cannot fine the wire in the car that shows Connect to dome lght wire that has +12V with the doors open
I am getting really really peed off at this moment! I cannot get anything to work at all.
Any help would be great!
