Is the diameter on the inlet and outlet ports on a non-ABS prop valve the same or is the inlet bigger?
Unless I am having a cranial meltdown they should both be m10 fittings.
btw where are you in ohio? I was out in the akron area for a couple months this summer.
Ashtabula County. About 2 hours away from Akron. I know the fittings are the same but I should have been a bit clearer. Are the hoses (brake lines) the same diameter?
it should all be 3/16" lines
Okay so all lines going to the proportioning valve are 3/16. So heres a question. Say I delete my power booster, swap in a Wilwood master cylinder, run a single line to just before the prop valve, split that into to two connect those two lines to the prop valve and run the rest of the lines from there. What size line should I use coming form the prop valve, and will it brake of just into the 3/16"?
