my car leaked a little bit of coolant and somewhere down the engine bay by cyl. #4 was smoking…nothing crazy.so just now i added sum coolant(it was mixed)…topped off my oil and checked my spark plugs…cyl. 3 and 4 have oil in them and the #3 spar plug was dripping a little bit when i took it out…also i put everything back together, started the car, and heard a lite but rapid knocking noise closer to cyl. 3 and 4. When i rev it to about 2k rpm…the noise quiets down…i NEED MY CAR TODAY-NEED HELP ASAP
http://www.g2ic.com/forums/announcement.php?f=29&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
