[QUOTE=ShadowxXxDragon;2044969]well…i used 10 30 on it and torqued it to 80 lbs
im using ARP headstuds for gsr[/QUOTE]
That could have been your problem. You might not have torqued enough to be honest with you. You’re supposed to use 30 weight (30w) oil, not 10w30. Also, and you might have done this, you’re supposed to torque in 25lb increments til you get to 80 lbs. i.e: All at 25 lbs, then 50 lbs, 75 lbs, 80 lbs. If you didn’t do that, you may have not really torqued it down the way your supposed to.
