Help
I am trying to flush the coolant since I am installing a new thermostat in the car. Now I am a little confused as to how I can drain the water. I removed both radiator hoses but I believe their is still water in the block thats probably dirty as shit. I cant unscrew the plastic drain cock on the bottom of the radiator for some reason (super low bad access fear of cracking?) so how can I do this?
http://www.g2ic.com/forums/announcement.php?f=29&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
