is the conversion really worth it? any problems?
pros and cons?
can tell me what your tranny set-up is too pleease??
thanks
pros and cons?
thanks
i dont know anything about the cable to hydro conversion but i know you will have a hydro tranny after. I like the feel of cable trannys better tho they feel alot more racey the hydros are too forgiving for me its almost like driving a auto to me now that i am used to the cable
which actuator do you plan on using ? convert to fully hydro or just use the cable actuator? i just did this a month or so ago and it work great so far minus the engagement point is a little different. also you will need to change the trans mount with a hydro mount from hasport or innovative.
