ok so i just got back from buying an automatic four door DB1 so ive been :read: but could not find an answer so here it is
as i drove the car on the highway i kept it at 55 and it had a real bad stutter
slipped a little bit going from 2nd to third.
now i know i need a tranny mount for sure because at idle it shakes like a salt shaker
but my actual question was if i clean the solenoids on the tranny will it make the problem go away??? what do i clean them with?
has anyone used oem fluid with lucas hard shift??? Because i know if the fluid is burnt and brown the tranny is on its way out any helpful insight to this is appreciated thanks
