Ok just swapped this motor in my car some specs
b18a1 bottom end w/ vtec oil pump(couldnt verify that though)
pr3 pistons
b16 head
type r cams
type r valve springs
aebs IM
h/e no cat.
Brief run down^
Anyway, 90 miles into my motor in my car and i noticed my oil light stay on 1-2 seconds after start up. I check the oil, about a quart low. Dump a quart in, i also have a slight leak from my drain plug i need to get an oversized bolt. I also just now added a pcv valve, stock IM has the fitting this IM does not, i just plugged the pcv valve right into the hose from the back of the block and then ran another hose to the IM port. With the car on the PCV valve, when you touch it is uhhh vibrating, not making noise but you can feel a lot of stuff going through it maybe with air(this normal?). Anyway the car still has the oil light on for 1-2 seconds after start up, i dont know if this is normal…I dont remember it from my LS motor.
Ok so thinking the worse i went out and bought a compression tester.
Open throttle, all plugs out etc etc…
left to right
215 230 220 220
did each cylinder twice…same everytime.
Im not sure what these numbers should look like with b16 pistons. Also all my plugs were white. With the car in “on” my fuel pressure is 47-48, with the car at idel its 39-40. The car has no cat, and has whitish smoke(more clear then white) like when its cold out side…smoke stays around id say 75% of the time. Ive had people ride behind me and they say it doesnt go blue so i guess thats good.
Ill get this drain plug leak free and then keep a close eye on the oil, only 10 of those 90miles were with the pcv valve hooked up. I dont really know what to do, need some more ideas? With those compression numbers i kinda rule out the rings right? Also supposely this motor had new rings and bearings about 4-5k miles ago. Had oil pan and eveything off all stuff looks nice and clean.
Oh yea and i have a weird noise coming from the motor, its a clicking thats a little louder then the valves starting around 2300-2500rpms. Now if i rev the motor 500-1000 rpms i can hear it…if i hold the revs anywhere it goes away(i think). It sounds like its coming from the motor but could be something vibrating.
TIA
AIm me at jetswu8924 with any questions or comments
[SIZE=5]EDIT: VALVE TRAIN NOISE SOUNDCLIP http://members.bellatlantic.net/~vze2qzh9/carsound.wav[/SIZE]
