1: June 2004 - The first one I had was because I bought a set of those eGay projector headlights when I first bought the car as a cheap/quick replacement for the mangled ones. The ground on the passenger side headlight wasn’t contacting fully in the 3 pin harness which for some reason caused my foglights to partially illuminate, radio would shut off at random, heater blower refused to work, and I couldn’t start my car unless I jimmied the headlight harness then retried starting. I have no clue how the headlight ground ties into all of it but once I replaced both sides of the headlight harness, the various electrical problems and starting problem went away.
Note: Avoid them eBay projector headlights. Wiring is poor quality, deflector globes inside come loose and dangle, then ya gotta peel the headlight lense and casing apart to get them out. PURE GARBAGE.
2: Spring 2006 - The little ground wires going from my radiator support to my valve cover, and the ground going from one valve cover bolt to another, kept melting and the car wouldn’t start. I’m extremely suspicious of this one because it was the only thing that was consistently burning out when the car wouldn’t start. Upgraded the wires to 8/10g wire, instead of melting apart they’d build up a lot of the blue-green copper corrosion and the problem would return. Changed the wires again to x2 8g wires between the valve cover bolts, a thicker core 8g wire from the radiator support to the valve cover bolt, ground a clean mating surface on the radiator support and the melting problem and corrosion problem went away. Wires don’t even heat up anymore. This one could’ve just been the mating surface between the wire terminal and radiator support. I’m still lost to the purpose of those little ground wires and how it affected my starting system. :squint:
3: Summer 2008 - Battery to engine ground cable. Radio would shut off when I’d push my brake pedal, heater blower motor would work erratically, and car wouldn’t start at random. Not sure where the problem in the cable was but the negative battery terminal started building corrosion (full coverage amounts) within a couple days so I bought a new ground cable/terminal, ground down the contact surface on the motor, coated any contact points in dielectric grease and put the new cable on. No more starting issues and no more corrosion issues.
4: Feb 2009 - Positive battery cable corrosion at the battery end. This one I dealt with for about a month, pop starting the car when needed, before [mentally] breaking down and spending an entire Saturday evening and into the night with a mechanic friend, a multimeter, and a bunch of Red Bull. It was 2 or 3am and was checking random shit when I noticed the 3v drop in my positive cable. The terminal had very little corrosion buildup but there was corrosion behind the terminal going into the insulation so I cut the terminal and enough wire till I saw clean copper in the insulation, grabbed a terminal off my buddies Fiero project, slapped it on and viola… my voltage drop at that point bounced between .4-.9v and the car started with no issues after that. I eventually bought a brand new terminal for it and whatnot but didn’t have another starting issue till my MFR went out in July.
I didn’t count the MFR going out as a starting problem cause it didn’t exactly stump me. Whenever I got the car started with these problems, she ran fine.
Just couldn’t start her unless I pop started it or repeatedly tried starting with the key until it would miraculously start.
And feel free to flame me for the projector headlights. I still flame myself for buyin those. :excite:
