Saw this ad on craigslist and had to laugh:
http://miami.craigslist.org/mdc/pts/1343562511.html
b18 or ls chipped compute for all motor ls setup ecu capable of 210 hp - $75 (chipped ecu with the chip included)
had it on an ls hith high comp pistons and a sheet metal intake and header made 210 hp to the reaar wheel has correct fuel and timing map for all motor setup (xxx) xxx-xxxx
phone number masked to protect the “not-so-innocent”
hahahahahahhaha 210 hp to the reaar wheel wow
you didnt know the sheet metal intakes and headers are the best for RWD integras 110%+HP performance
man… totally need to pick this up for my build. i cant seem to keep the rear wheels planted on the launch!
Found another one tonight:
http://miami.craigslist.org/brw/pts/1346543651.html
brand new unorthodox crank pulley b16 b18 honda acura b series civic - $65 (pembroke pines)
have a brand new in box never used unorthodox crank pulley for all b series motors b16 b17 b18, this weighs only 2 lbs while the stock solid metal one weighs almost 20 lbs, thats why it makes you engine rev alot faster and gives you atleast 10hp to the wheels and alot more torque tq. this pulley is much lighter than the type r crank pulley aswell and you can keep a/c and power steering i paid over $200 brand new now i need the cash so first $65 takes it call
WOW, I didn’t know the stock crank pulley weighs more than the flywheel!!!
LMAO!
