Top 10 Fastest 1/4-Mile G2's V.2
Since the other thread was abandoned years ago and no further updates were available, I will do my best to keep up with timeslips and updates on this new TOP 10 Fastest 1/4 mile G2’s.
FORCED INDUCTION
[B]
  1. db2-gzr-lv - 10.448 @ 148.36mph - Slicks
  2. Integrated93 - 10.98 @ 135.89mph - Slicks
  3. Tchleung - 11.18 @ 140.86mph - Notable Video 1 ,Notable video 2
  4. Turbociv910 - 11.26@124mph - slicks
  5. 92notec - 11.30@128.25mph - slicks
  6. Turboteg - 11.55@ 129mph - slicks
  7. Teggyracer18 - 11.57@119mph - slicks
  8. kmaz93da - 11.87 @ 120.34mph - slicks -Notable Video
  9. Smokeintegra - 11.95@118mph -slicks
  10. Hamfab - 11.96 @ 120mph
NATURALLY ASPIRATED
  1. Fym allmotor - 12.2@111 -Notable Video
  2. gTIntegra - 12.8@104 - Slicks
3) abs-lsd - 13.49 @ 106.86 - DR
  1. Hondatec38 - 13.6 at 103.3mph - DR
  2. AllMotorDA - 13.8@98.26 - Slicks
  3. G2guru - 13.92@100mph
  4. viprtwo - 14.2 @ 97mph
  5. Integra GS - 14.247 @ 96.80
  6. darnizzle8805 - LS-Slicks 14.414 @ 96.21mph
10)Stevo-DA - LS-Vtec -14.594 @ 95.78
[/B]
[B]Post up your:
  • Fastest Times With slip
  • Dyno Sheet
  • Videos (if you got em)
  • Set-up (N/A,Turbo, Supercharged, Nitrous)
  • Tires (Drag Radials, Slicks, Street)
No updates if no time slips or video showing time!!! NO EXCEPTIONS!!!
---------------------------------*** List will be updated as memebers post their times ***[/B]
Update my time
Normally Aspirated
2.2 60ft
13.6@103
2500 lbs with driver
89x81mm LSvtec
Full interior, full exhaust
Post up your:
  • Dyno Sheet
I had 25" x8 x13 MH full slicks
http://www.youtube.com/watch?v=dGTF2Q2HC-M
Ls vtec, gt35r, SLS ram horn(t3/44) , 18 psi, J1 cable non lsd trans, dss stage 3 axels, Motec ECU.
13.1 @106mph
2.0 60ft
Here’s My time and WHP! With B18/Vtec:
Integra 90 All motor On dyno with B18 hybrid…228WHP!!!.. By JD Performance and Tunning in Puerto Rico
Engine Specs :
B18a1
Pistons PCT
Head B16
Skunk 2 Seleniod Cover
Sprocket Skunk2 Tunner series
Coil MSD
Intake Manifold CTR
PVC Intake
Fuel Regulator
Fuel rail Skunk2
Cams Skunk2
Valve & Retainer Skunk2
Sprins Omni Power
Tranny B16 Sir 4.40
Flightwheel ACT
Catch Can
Header Tri-Y Regular tube
Throttle Profetional product
Exaust 2 1/2
P28 Crome
Without Electrical Water Pump & ITB
Dyno :
Dyno Video!
http://www.youtube.com/watch?v=jwkQeIBrNZM
Slips
Here’s the Video
http://www.youtube.com/watch?v=Db9R5iK0zNo
Pics Of the Cars
all updates. Nice times and car. need to take the #1 spot…run a 12.79 or faster. I know your capable of it.
Thanks a lot… we know the car cant make best number, right now we’re making a correction with the reaction, wheels, suspention, and that they we going to the track run with the damage alternator…that day we run out of tunning but we going to the track with best reaction and best 60ft…for best time in miles and in the 1/4 mile… Thanks!!! that #1 it’s for me!! lol
heres a video of my DA with built LS v on a LS trans with street tires best run was a 14.594 i have a y1 with 2way LSD now havent had a chance to go out and run it but will soon hopefully
http://www.youtube.com/watch?v=t6KELf10oYE
just added the update. is there not 1 G2 that runs all motor in the 11’s? I know there has to be quite a few, but we are a scarce crowd. represent G2IC!!!
im pretty sure id be low 13s high 12s with slicks with my new b16 LSD trans just havent had time to go out with it, also got the new header in the pic hope to get a run in befor i leave for basic
just went back to the track wednesday and I ran the same time as posted. but a higher trap speed of 119MPH, so I decide I’m going to go for broke.
I lowered the pressure in the 24.5 MT’s and up the boost a lil and take off at almost redline. the results…broken driverside axle on a 1-2 shift, but i picked up enough speed in 1st to get me all the way down the track, then I got towed back.
pretty funny, that I have never broken an axle. I always preload but what to do for a 1-2 shift??? I have no idea. as I have time to get it off the car, I will post pics so all can see.
oh and best of all on that run I got my best 60’ ever of 1.6, too bad I couldn’t follow through with the rest of the gears…lol
didnt get to make it back out this season befor i leave so il try and move up some spots in the N/A group next year
heres the driverside broken axle. it broke at the spline as you can see from a 1-2 shift. I managed to gain enough speed to still get down the rest of the track
ohh:shock: i think you need a racing axle for the best 60ft and reaction!!!
[QUOTE=turbociv910;2045934]I had 25" x8 x13 MH full slicks
Ls vtec, gt35r, SLS ram horn(t3/44) , 18 psi, J1 cable non lsd trans, dss stage 3 axels, Motec ECU.[/QUOTE]
just curious, if i may ask, what all is done to the motor?
that fuckers quick bro…good work
Specs
Brian crower stage 2
Crower Springs and retainers
supertech valves
62-1 Master Power Turbo
Pfab log manifold
turbonetics evo wastegate
greddy Blow off valve
Golden eagle sleeves
81mm Cp pistons
eagle rods
Obx Lsd
ACT Clutch
Stock Flywheel
1000cc Rc
Aeromotive Pump
Aeromotive Regulator
Full weight car with amp and speaker etc…
Tuned by Geronimo Racing with Haltech
110 Oct 26-27 Psi 517 whp 10.98 at 135mph
After i made that pass since i don’t have a catch can for the moment it leaked a little oil at the track and couldn’t race no more and on top of that they seen that i didn’t have a roll cage. That was my third pass, the first and second pass the car was misfiring then my tuner told me to change the plugs and that was it the car clear up and made a pass. Im going to the track again before it snows because i know that the car can go 10.60 or even better who knows.
http://www.youtube.com/watch?v=ecedzugpd0A
http://www.youtube.com/watch?v=2jvIzYIA8Wk
http://www.youtube.com/watch?v=uvYE8WlfJMU
Wow you knocked off a lot of time.
wow. that’s the buisness man. all done with a LS. WOW!!! that’s a accomplishment in itself. all updated. I’m loving the car integrated. what traction bar is that I see???
