wondering if i will be able to pull of a hellaflush look with 16x7 +45 offset looking to be sitting on ground controls eventually. currently sitting on tokicos with sportlines
how would 16x7 +45 look with approx 2inch lowered?
Haven’t you searched for low offset threads? The only way you can make it fit and look flushed is to roll your fenders to the max, have stretched tires and slam the car to the maximum degree of difficulty!
The only DA’s I’ve seen that are decent with a 16x9 0+ offset are Rexone’s and that one guy with the white DA rolling on Sportmax… even with that… it looks like crap from the rear… whatever floats your boat dude.
Search for low offset threads and you’ll see that 99% of the cars posted in there look like shit. Stop the nonsense! :bang:
I am tucking about an 1/2" of tire. 16x7 +33 offset fno1r-c’s, 215/45r16, -2f/-2.5r camber. Future plan in about a month or 2 is to go to a 225/45r16 or a 225/50r16 and increase the camber a smidge.
Yeah japanjay’s setup is actually a really good fit and not too overdone. I had 16x7 +40 and was running 215/45/16 and it tucked perfectly right at the fender… looks almost flush but not too much so I didn’t have to roll fenders or worry about rubbing over bumps…
go to honda-tech on the “post your low offset wheels” thread. i think it looks pretty sick if done right. i like phase2’s white DA. it looks pretty good.
im running 15X8 +15. stitting hellaflush. i rolled the rear, made the rear have more positive camber, took out the plastic in front and rolled the front fenders, rubber is 195/50/15 hankooks. I think this intense. If you want to sit hellaflush this is what it takes. =)
glen you got any pics 50 probably rides a lot smoother than 40’s and 45’s i bet but i have +45 i would like it lower but my cousin gave me the wheels so i guess ill see how it looks. do i really need a camber kit? is it true that the other camber kits that have the screws on top like dent the inside?
hmm for the da’s i think the rear offset looks good but the front looks a bit funny looks like the front should have like +30 or something not sure if want to hellaflush my teg if i stuck with getting a 240 i definately would’ve
