does anyone know if the suspension off a 95 civic will fit our cars? Ive seen people do it before because the rear forks are the same and the front forks you just use your stock ones any help will be appreciated
http://www.g2ic.com/forums/announcement.php?f=30&a=13
USE APPROPRIATE SUBJECTS
