would the 94-97 type R shocks fit my 1992 integra?
Or would i need to use the 94-97typeR forks, control arms, etc.?
thanks
-karlo
thanks
-karlo
type r suspension
to use the R suspension from a DC chassis integra you will need the front forks cause they are wider then the EF/DA ones. You will also need the rear trailing arms cause its a eyebolt style not a fork like the DA. If you are trying to use a stock Type r suspension the rears will be a lot lower then the front. If you are using a aftermarket coilover then you can adjust them so its cool. Hopefully this helps. i know about the stock shit cause I tried it before.
