Function 7 LCAs W/ ABS
i got a set of function 7 LCAs and im not sure on where to relocate teh ABS lines that run across teh stock LCAs. Can someone please share what they did, or would do? im not trying to mount them on the F7s visibley, if possible id like to hide them compeletly.
thanks
do an abs delete
Solution 1 - Zip ties are your best friend
Solution 2 - Lengthen the wires and reroute (along brake hose or anywhere else you like)
I duno if removing the entire abs system or even disabling it is worth it because of two untidy looking wires…
