I’ll get you some pics tonite. I just finished doing mine. You can use a prop valve from a non abs car. You also need to make extensions which I can show you how I did it. you don’t need different axles. Both witll work. You can remove your abs sensors as well. What you will need Is a non-abs brake booster and master cyl. It makes things much easier. Also get yourself a mighty vac. It’ll help bleeding the brakes easier.
Yea man, any pics would be oh so much greatly appreciated. I just dont want my car to be down for more then a couple days so thats why im kinda leery about the abs delete and what not.
IF you have all the parts you need to do it, it’ll take you a day at most.
Here is the procedure.
Pull ABS fuse/backup
Remove ABS booster and master cyl
Remove ABS brake lines for front and prop valve
Remove ABS pump and accessories
Install new Prop valve
Measure distance from new non abs prop valve to the rear distribution block for the rear lines. Don’t need to remove it. just need to cut up old lines to make extensions for new lines.
Cut old lines and use old fittings and a flaring tool to make the extensions. Install extensions.
That helps a lot. You are talking about flaring the lines. Can you give me a def. of what this is exactly ? and those steps are very clear. What is a mighty vac ?
you need a brake line tool kit you can rent from a parts store. if you dunno how to do it, you’ll need to find someone who can help you. it takes ordinary tube and makes the ends flared so they seal inside the brake fittings.
mighty vac is a hand held vacume pump for bleeding brakes and clutches.
this is WAY late but yea. you can see the sections of brakeline we cut and flared and bent to fit. its a tight fit when done right (imo) and doesnt’ leak a bit. bleeding determined it was a nice steady flow through those lines too.
Me to, I just went to the scrap yard and pulled off all the front lines and the prop valve from an RS. I cut the M10 fitting off the rear MC port and put the M12 from the abs lines I pulled out.
yeah, personally I like keeping the larger master cylinder. I don’t mind the pedal feel with that setup and it leaves you in a better position to upgrade to larger brakes in the future.
this is WAY late but yea. you can see the sections of brakeline we cut and flared and bent to fit. its a tight fit when done right (imo) and doesnt’ leak a bit. bleeding determined it was a nice steady flow through those lines too.[/QUOTE]
Heres a question. Why are you running your lines from prop valve to prop valve.
