I was wondering is there any swap for the DA to make it a 5 Lug? I remember seeing somewhere there was a DA with RSX wheels on it, does anyone have more info on this?
5 lug swap from a usdm type r
http://technet.ff-squad.com/how-to/5lug.ef-da/
http://www.honda-tech.com/showthread.php?t=1978033
:read:
I have it done to my car and I can tell you it’s not a bolt on thing. If you want to do it correctly there is some machining that needs to be done to the hubs. You can also use JDM ITR suspension but you’ll have to run 36mm axles instead of 32mm.
