the drop on sports is what, 1.8 inches? Camber spec is 0* + or - 1*, so you could probably use either, you are going to be needing right about 1.5* of correction probably. The -1.5 to +1.5 kit will allow you to add more neg camber if you want it in the future.
to a point, more negative camber will aid stability and grip when cornering. The only time you would probably want more than -1* is when doing some hard driving, autocross or such.
