Iinstalled a set of coilovers on my 93 integra and theback is fine I can lower it the whole way and it will be way low but the front only goes so far, i know it supposed to go farther (ive seen it) all i have it stock shocks but I know it can go lower. If someone could help me out that would be great, thanks :think:
Just an FYI - Those stock struts will not last very long.
On a different note. Is it hitting the bump stop?
Like Wraith said… did you cut the bump stops? Also, did you remove or cut the dust covers?
No dust covers, the bump stops I didnt cut but will that make a big difference?
The bump stops shouldn’t make a big difference, but you should cut them at least in half. That way you won’t be hitting the bump stop all the time.
