Now that it’s winter, and most of us drive in the rain, or in the snow. I thought I’d share this with you all. Feel free to make any comments or corrections.
Here are some things that I thought about after I reading a few Carroll Smith books, Race Car engineering books, and then later after some very long spirited driving with a FWD car on very technical roads in the rain.
Keep in mind when entering a turn, weight will move to the front corner which is being loaded.
Feel for the moment of understeer. Depending on the tires you have, and entry speed, etc…either the moment of understeer will occur quickly, or rather gradually.
Gradual understeer will appear like you are not turning the steering wheel enough, and need to tighten up the turn.
Power-on-understeer will be feel as though the car is moving forward only, regardless of steer angle. And the car will no longer have a continuously changing vector (i.e., steady state turning), but rather will just plow straight ahead, following the path of the rear wheels, rather than the steer angle of the front wheels.
If it’s raining, and you are tuning hard, and suddenly increase throttle drastically, the front tires will be shocked, and the car will not change direction (which the steering tires are used for) and will track along the path of the rear tires.
When the understeer limit is reached, especially when you are in the rain, the best thing to do it back off the throttle and ease on the brake.
Engine braking will cause the front brake bias, which is further detrimental to stopping, because the rear is already neglected for its stopping power. Although engine braking in low traction condition will not cause wheel lock-up unlike brake calipers without ABS. This is due to the continuous rotation of the engines’ rotating assembly.
Transferring heavy load to the front tires (or shifting the cars weight to the front) is also a bad idea in heavy rain, because this will cause the tires to reach front tire traction limits sooner.
When cornering limits are reached while you’re driving, it is usually gradual. Initially it will feel as though the car is pulling inward (towards the inside of the turn) and while holding the steering wheel at that same steer angle, the car will FEEL like it is no longer pulling you towards the inside. (Of course this is assuming the consistency of the turn is a controlled variable.)
Feel for the “hold” and “release” of the cars turning force. It will feel like a gradual climax, and then a drop off. (It will drop off suddenly is extra thrust is applied.)
Keep in mind FWD’s car weight is in the front, (as well as the drive wheels in the front.) This makes the car a double loser, because the front wheel drive overloads the front tires too soon, as well as the front weight overloading the tires too soon as well.
(Obviously: The capacity to take a turn faster, smoother, and shaper, lies within RWD or AWD cars.)
When you are driving in low-traction conditions, try to drive as smoothly as possible. Especially if you’re pushing 200+ HP on the front wheels. You will meet power-on understeer VERY quickly.
Also, when taking turns in rainy weather, if you are accelerating during the turn, up-shift, and then drop the engine speed to low-rpm’s, it is possible to clutch-burn brake, by balancing sitting in between neutral and full gear engaugement. (Careful though, doing this too much can burn your clutch—but the benefit to this is avoiding wheel lock-up.)
Also, if your turbo’ed, be wary of boosting suddenly in the middle of a steady-state turn. (Steady state turn refers to a car turning without understeering or oversteering. And operating at a constant tire slip angle.)
With less horsepower at little or no boost, throttle inputs are much more predictable.
The opposite of this is holding the engine speed at 7,000 RPM’s, while at 0 boost, and suddenly in the turn (steady state), your right foot gets a little heavy, and 15psi of boost kicks in, causing power-on-understeer.
Simultaneously, holding 6.5K RPM’s engine speed or so in the middle of the turn, can better prepare engine throttle and acceleration while exiting the turn.
Bogging the motor to lower RPM’s in the middle throughout the turn in a low-traction condition will give predictable turning, due to less division of tire traction, between the vectors of TURN and THRUST.
Keep in mind whenever you brake, turn or accelerate, you divide the traction of your tires. For example, a single front tire can only have 100% traction capacity. Your front tire on your FWD car, when entering a turn REALLY hot, and braking hard and late, you use 75% for braking. This leaves only 25% left for turning.
A good driver will gradually make shift the job of the tire from 75% braking, more to turning, say 50%, and then 50% for accelerating.
This is known as riding the traction circle.
The traction circle (or traction capacity) is even less while driving in the rain.
Given that your front tires do ALL the turning, accelerating, and almost 90% of the braking, your front tires will reach its’ limits VERY soon. Even sooner than usual when it’s raining.
Often, with some front engine cars, (without ABS) upon hard braking, only the front tires will lock-up, and rear tires will keep rolling. This also depends on weight distribution, and dynamic brake bias.
Depending on the distribution of braking power of your master cylinder, as well braking power of your rear brakes, it is actually helpful to PULL the E-brake, to boost the rear tires braking power, but NOT to the point of lock up.
While braking while turning in the rain, A LOT of caution should be taken while pulling your e-brake to assist in braking power. Employing the rear brake more (but before the threshold of lock-up), will help lessen the braking effort needed for the front brakes.
Keep in mind that only engine braking, causes 100% braking power to be on the front tires, and 0% braking power on the rear. This can cause brake bias, and when coupled with caliper braking, the front tires will lock up VERY quickly.
Depending on the situation, the best way to utilize all components of brakes, tires, engine, and suspension, can be a combination of caliper braking, engine braking, and e-braking, as while turning the steering wheel, while feeling the car for it’s moment of understeer.
A word about tailgaiting in the rain. (As well as in the dry.)
Also, if you’re tailgating someone really close, your car had better be able to out-brake that car in terms of stopping distance.
Say for instance, we take a 1400 lbs 1965 Mini Cooper, 305/50/13R sized tires on all 4 corners, with 6 piston AP Racing brake kits on all 4 corners. (Overkill, I know.) The car is driving 75 MPH on the freeway.
Next to our Mini Cooper, is a 8,000lbs Lincoln Navigator SUV, and for some reason, he’s got 165/70/14 sized tires (the Wal-Mart special) on the behemoth. He also has stock brakes.
These two cars are doing the exact same speed: 75 MPH.
Suddenly the both slam on their brakes as hard as they car, both cars braking on the edge, right before lock-up.
The SUV probably takes 50% more stopping distance than the Mini Cooper.
Now for application. If this Lincoln Navigator is tailgating the Mini Cooper, he is a MORON. (The SUV will smash into the back of the Mini.)
If the Mini Cooper is tailgating the Lincoln Navigator, he’s being an aggressive driver—let’s just hope his reaction skills are as sharp as his car.
In this case, the Mini will slow, the distance between the two cars will increase, and SUV will maintain it’s momentum longer, and will stop LONG AFTER the Mini Cooper is parked.
Moral of the story: ONLY TAILGATE, if you know your car can out-brake the car in front of you, and that your reaction skills are like that of a cat.
Side note:
The idea behind understeer and oversteer. If the rear tires break traction first, then the rear end of the car will pivot around the front end.
If the front end breaks traction first, then your front end will pivot around the rear end. (Although, not nearly as much compared to oversteer, and rather the car will only slide straight, because the tire slip angles are increasing as understeer increases.)
Anyhow…these are a few things I’ve been thinking about. And not everything here has been my idea. Alot of it is paraphrasing. (And congrats to you on reading the whole thing.) Let me know what you think guys. I hope somebody got something out of it. In anycase, be safe out there in the rain.
-Andrew
