hey…i just changed all my brakes and now when i’m driving around…i hear a sound coming from my front right tire which sounds like metal slightly grinding on metal…is there anything i should look for that i should fix or is there any thing that i should do (bleed brakes…stuff like that)…any tips will help…thanks…
Did you use any brake goo on the shims?
one possibility could be that the dust shield behind your rotor got bent while you were working on it. it could rub on the rotor and make some noise…
I’d check that first…
i should prolly tell you guys too that i hear the sound while i’m driving…not while using the brakes…
Dust shield
dragging caliper???
arite…i had to buy a new caliper hardware kit and change that…just lettin u know just in case anyone else had the same problem…thanks for the help guys…
