I’ve done a search with no luck. Here’s the issue:
I bought a set of yellows used for a 90-93 teg. Called Koni and was told to drill out the insert in the stock upper shock bushing to 12mm (inside dia.) because the shock rod is thicker then stock.
My question is this, is there a better way to do this? maybe parts off of a 94-01 teg? Or did the inserts come with the new shocks?
Any help is greatly appreciated.
George
