I want to replace my front lower control arm bushings, but I don’t want the axle to slip out and waste my new tranny fluid. Is it possible to take out the lower arm without leaking tranny fluid?
yes.
Ben
i think i’m gonna use a coathanger to secure the bottom of the knuckle to the chassis just in case.
you dont have to take the axle out to replace the bushing.
the best way is to replace the whole control arm, unless you have the proper tools to take out the old bushings.
^^dremel… check. propane torch… check.
