I just bought my Integra and I want to keep the stock rims because in autocross tires go fast, so smaller rims equals cheaper tires. Anyways Im running on 205/60/14 how low should I go considering my tire size? I was thinking about the TEIN S-Tech 2 inch drop does that sound good?
If you’re autocrossing and changing your springs why are you getting such low rates?
Here is my car with stocks and STech’s & GR2’s.
http://www.g2ic.com/forums/showthread.php?t=101812
The car actually settled down to where there was a finger tight finger gap. Couldn’t make it over any speed bump without scraping, even the long/wide low speed bumps. I switched out to Ground Controls and am a lot happier. Will be getting Koni Yellows later on down the road.
Yeah, I wouldn’t go with low spring rates for autox. My brother put Eibach Pro-kits on his RSX and you can feel the lag from body roll when he changes direction.
This winter while my car’s in storage, I’m putting Koni Yellows and Maxspeed coilovers (572f/472r) on. We’ll see how it handles next year at autox
