very common problem. First off, lowering more in the front doesn’t mean you’ll end up w/ less gap in front… this is because the gaps aren’t even to begin with. Second, the common problem of “uneven drops” may not really be a problem (at least not from a performance standpoint). Companies, surprisingly enough, may have actually done some R&D. Our cars are heavier in the front, lowering the rear a bit more will help even out this weight distribution problem.
I mean Eibach’s are supposedly some of the best riding springs, and it does ride fine, great actually… I’ll have to snap a picture, and post it, and see what you guys think. Thanks.
Yes, it’s normal. If you have, or get Koni Yellows, you could even it out by placing the spring on the highest rear perch, while the front shocks were at the lowest front perch. You will get used to it though, that’s how those springs are designed.
