Answer these please lol
ok so i just got back from buying an automatic four door DB1 so ive been :read: but could not find an answer so here it is
  1. as i drove the car on the highway i kept it at 55 and it had a real bad stutter
  2. slipped a little bit going from 2nd to third.
now i know i need a tranny mount for sure because at idle it shakes like a salt shaker
but my actual question was if i clean the solenoids on the tranny will it make the problem go away??? what do i clean them with?
has anyone used oem fluid with lucas hard shift??? Because i know if the fluid is burnt and brown the tranny is on its way out any helpful insight to this is appreciated thanks
http://www.g2ic.com/forums/announcement.php?f=29&a=13
USE APPROPRIATE SUBJECTS
