Test: Pulled each spark plug wire to check for spark to help my idling problem. (sounds like mis-firing)
Result: #1 and #2 seemed fine, heard and saw sparks.
Pulled #3 or #4 car bogs then dies.
Other info: 154,xxx Stock B17A1 w/ P61
<ul>
<ul>
blown HG between 1 and 2?
First things first, you need to deal with that CEL. Sounds like you’re running in limp mode. Also, If you’re plugs are black and smelling of gas it’s running rich. Borrow an ECU from a friend, and put it in… If the CEL goes away, you have a bad ecu.
Funny thing is though i can rev past 3k rpm.
Does the CEL go away when you rev past 3k? If not, then you should be worrying about that before anything else.
nope. Yeah idk whats going on but for now wont have time to diagnose since college is taking most of my time and money.
