Hello,
Here’s the long details. You can jump to the bottom for the questions I have.
I have a sound coming from the car (pretty vague I know.) It was very difficult to tell if it was coming from the front or back. Over the past 4 weeks it has become louder.
- It sounds very much like when your axel is going.
- Only when driving
- doesn’t matter if it is in gear
- it doesn’t get louder if I turn left or right
- It is not a constant pitch noise like the typical rear bearing issue
- It is now definitely from the front, but can’t tell what side.
- I checked the brake calipers to make sure they are tight
- I checked the axles for any tears.
- I spun all four corners without the tires and felt no resistance or grinding.
- I moved the front wheels left and right and up and down and all is tight.
- If I do figure 8’s in a parking lot, it does not get louder in either direction. It makes the noise only if I go straight or turn the wheel about half circle to the right. Beyond these points you don’t hear it.
I have basically narrowed it down to:
- Inner axle joints
- Front bearing in the hub
- Intermediate shaft bearing
I don’t think it is the outer axle joints since it doesn’t get worse when I turn to the extremes. The front bearings are a possibility but unlikely.
Also in the past two weeks I started to hear a clunk or knock when coming to a halt or as soon as I start to go. I am wondering if this is related.
My friend suggested it is one of the tires (not the rim). He had a case where he was going crazy thinking it was an axel and when a mechanic put it on a lift he showed him that the actual tire was warped.
So question are:
- What does it sound like when an inner axle joint starts to go?
- What does it sound like when an intermediate shaft bearing starts to go?
- How much does the bearing go for? And is it available at only the dealer? (Please suggest Canadian/MTL shops)
- Does the axle look properly seated into the half shaft in the attached picture? (I may have oil leaking from the half shaft like you see in the pic, but I also realized the oil filter is right above it and may be the culprit of the oil leaking)
Thanks for any of your input.
