So I’m cleaning up around the battery tray and there is some minor surface rust on the frame right below the battery. What’s the best way to get rid of the rust and coat the frame? Sand paper, grinder? What should I use to coat the bare metal? Thanks fellas
wire brush or sand paper you could probably just use some rustoleum product to be safe you could prime the area where the rust was first than lay down your color coat.
