Does anyone knows how to adjust the clutch… in my car is to high, and i would like it to be like around the middle…
please let me know…
thanks…
We are lucky in the fact that we have a cable clutch that takes a few spins of the wrist to adjust, no tools needed.
- Open the hood and look at the battery.
- The cable adjuster is to the right and below the battery tray. It points upward. There is a plastic collar that you spin up or down to adjust. Its easily accessible.
- Give it 2 turns then hop in the drivers seat to check the feel.
It may be easier if you have a buddy that is not an idiot or drunk help out under the hood while you check the pedal feel.
I would recommend doing this in an empty parking lot or non busy street. Sometimes it takes a few attempts to get it perfect.
If you can’t adjust it enough then you may have a stretched out cable. It happens a lot on older Honda’s. I’ve replaced a few and its not incredibly difficult or expensive to replace yourself.
Good luck.:sipread:
