I’m not getting any fuel pressure on my b16… wont start…
If you are not getting fuel pressure either the pump is faulty , the MFR needs replaced, you have a kinked line or clogged filter or bad ECU.
Start testing by listening for the relay click and fuel prime sound (fuel pump buzz sound). If no sounds try replacing the B16A ECU with the original ECU and test again. If you get fuel pessure with the original ECU the B16 ECU is bad.
thanks I’ll try that…
hey did replacing the ecu help you out? im having similar problem and id like to know
thanks
