I had a few problems with my soleinoid before but i fixed it up and now i am leeking oil from the seal at the soleinoid to the head. I had the problem before and i fixed it with new seals but its leaking again i dont want to buy new seals every two months so do i mabe need a new soleinoid? or should i try to re tighten the soleinoid down at a glance it looks like there is no gasket at all but i know there is. any help is apperciated
anyone have this problem tried to retighten it down and still leaks!
just an idea make sure the gasket is seated correctly and maybe some high temp RTV silicone sealent.
orite ill try that i just dont want to replace those again
don’t use any sealant its designed to work w/o it.
get new OEM gaskets and filters. you need two parts from honda. one seals the solenoid top and bottom, the other seals the solrnoid to the head.
make sure the parts are OEM, that all surfaces are clean and blemish free, and torque to spec.
oh and make sure the filter is positioned correctly, there’s a groove in the gasket for it to sit in.
oh sweet ok man i shall try that
