Will a stock GSR exhaust direct fit to an LS? Anyone had experience with this and is there any difference in sound between the two? I’m probably going to buy a direct fit bosal.
GSR exhaust will fit on a 92-93 teg. check P/N’s on delray Acura . com I’m pretty sure that the LS and GSR exhausts are the same part number.
I stand corrected, the B pipe is the same exhaust is different. It should still bolt up with no problem the difference is probibly internal with the baffles.
GSR P/N 18307-SK7-A72
LS P/N 18307-SK7-505
