Hey all, i have to codes that keep coming up after i drive for about half a mile…i have a 90 with a 98 ls but still using the 90 mani…my first code is 10=intake air temp…could that just be the sensor on the fourth runner?? second code is 20=electrical load detector…my battery is dead and have not replaced it in a long time…could that be the problem? i just wanted your 2 cents before i start buying the wrong parts…thanks you guys for looking and your help…
the eld error cannot be eliminated unless you swap in a fuse panel with an eld (92-93 teg from what i’ve heard). it will not affect anything and should not show up if the jumper is off. it by itself will not trigger a cel.
the second code may have to do with a bad connection or a faulty sensor. good luck!
thanks a lot for your help…ill proceed and will let you know how it goes…cheers!
