yeah it happened…it use to drink oil…i forgot to check the oil one night and bam there she goes:(
what are some of my options…please help
replace the oil pump now before you blow the motor
thats it…i had some mechanic tell me i eeffed up the piston or something…my spanish isnt that well…also one of cams moved not sure if they moved front or back
it jumped most likely a tooth or 2. just because your pump went out dosent mean your pistons are fucked as long as you didnt drive it after at least that is what my last da did. or it could be the oil pressure switch.
but wait before you do anything till some more skilled people tune in.
