Say when removing the main fuel relay do you need to remove that metal plate in this pic:
Because it’s a bitch to get to the MFR with this thing attached, I see two bolts on the left side but I can’t to locate the ones on the right they disappear behind the middle center console, so do I need to remove this console as well? or does everyone just use an extension to their ratchet to take the bolt off which holds the relay on?
