I’ve long been a fan of this site, and as an original owner I reference it often to keep the 16 year affection I have with this car strong. All you guys and gals gave me the courage to attempt maintenance and upgrade jobs that I never thought I was capable of; gotta hand it to you all - there is some real creative and skilled talent that contributes to these pages.
But now I wonder if I skrewed things up royal. Yesterday I set the valve lash for the first time, a real feel good DIY job I thought. Rode well for me for a few miles but then horrible sreeching under the valve cover, timing belt side. Limped her home, opened the top and saw that the plastic guard on the motor side of the timing belt sort of melted into the timing belt teeth, both intake and exhaust sides. Also noticed that the #4 spark plug connector was oil stained. Could a bad head seal causing oil to douse that plug generate heat to distort that plastic? Also installed a new alternator at the same time; could that have generated excess heat with a too tight belt or something. I’m lost, July 4th travel plans hosed - please help.
