A/C Install guide
A/C Install guide
    A/C Install guide
    Does anyone know of a good site that has a reliable AC install guide for a 93 Integra GSR?
    If you do please post it up.
    like what exactly are u looking for? why don't u make sure u get all the components first, then get a helms manual....... and then go from there.
    question tho, are u missing the engine bay components for the a/c, or are u also missing the parts that are under the dash?
    its fairly simple tho.
    u need the following:
    evaporator
    blower motor
    a/c duct thing
    high side pressure lines
    low side pressure lines
    a/c o-rings
    condensor
    compressor
    compressor bracket
    a/c idler pulley
    condensor to compressor lines
    receiver/dryer
    refrigerant oil
    refrigerant
    a/c fan
    the system will need to be serviced, and the right amounts of oils will need to be put in, some parts will need flushing, if u are retrofitting then u will need new fittings to the service ports, and a receiver/dryer that is brand new to go with the retrofit.
    if i missed anything just post it up.
      I have everything that goes under the dash already installed. I picked up a full DA Integra AC system today and bought a compressor mount bracket from a friend.
      I actually found an online .PDF manual for the DA and I'm going to use that as my guide.
        perfect.
          Here's the site where I found the manual.
          I just glanced over it but it looks like every manual for every Honda. Useful guide.
          http://www.hondahookup.com/manuals/
