so i got my exhaust finaly fixed. when im mashin through the gears, at about 4,500 to around like 6 or so rpm i get white smoke, mixed with a little tiny bit of blue. white smoke is usually coolant right? also a sign of a blown or leaking headgasket. blue smoke is burning oil (its a honda so idk) but im just wondering if anyone has had a problem like this and ended up replacing the head gasket. i want to know if it stops the smoking. it smells like coolant outside of my car. very unatractive smell.
leak down test.
what is that?
it means u need to do a compression test and a leak down test…
if u don’t know what it is or what they are… u can search or google it. they are tests regularly performed when checking the condition of the motor.
oh, ok.
