ive got my 91 rs and it wont shift out of 2nd and the s4 button dont work. could somebody help me out til i get the money to do manuel swap. thanks
#1. Do you put it in D ?
(I’ve seen ppl start it in “d2” and wonder why it wont shift)
#2. Try changing the transmission fluid. Teg tips:
http://www.g2ic.com/forums/showthread.php?t=39620
Make sure you use Honda Automatic Transmission Fluid (ATF)
#3. The S4 button only works when you select S3 and is ready to shift from 3rd “gear” to 4th.
I say change the tranny fluid to see if that helps. I had a crapload of problems with my transmission on my auto teg when i first got it. As soon as I followed that tegtip and changed the ATF, it solved 99% of my problems…
when i put it in D itll shift 1st and 2nd then slip out so i have to pull it down to 2. it worked fine until i parked it for several months. this weekend i can get some honda atf.
Ah i see. The “slip out” thing. Like when you accelerate and the car wont shift.
That’s one the problems I had that was fixed by changing the ATF.
Change it and lets us know how it turns out.
thanks man ill get to change it this weekend
please don’t ever get a power flush for your tranny acura does not recommend it for our cars it could do more harm than good
