it has been almost a month of troubleshooting, search (yes, I have searched here, honda-tech, team-integra, etc) and cussing. now I really need suggestions since I hit the dead end. car does not start.
One day the car (93 GS) suddenly died on the highway. after towing home I started to figure out what it was. Apparently- no spark (there is fuel). So far have checked:
- All fuses- under hood and under dash- all OK.
- Spark plugs and wires- all OK, work in the other car just fine.
- Main relay- tested OK, there is 2 sec delay and click, fuel pump is priming, plenty of fuel on plugs. (took relay out and checked as instructed in helm’s manual)
- Main Relay harness connections to ECU- all wires OK,
there is connection between the relay and ECU,
there are proper voltages , even the starter signal is present at ECU.
also, there is 0 V for first 2 sec, then 12V at ECU. (at this point Helms manual tells me to test main Relay again… dah, just checked it. - Distributor- cap and rotor OK, replaced from working car, still no spark
Ignition coil- replaced from working car, still no spark
Igniter, ICM- replaced from working car, still no spark
Performed ICM input test (per Helms manual)- all connections OK.
Swaped the whole distributor from working car- still no spark. - replaced ECU from (allegedly) working car (actually bought it from somenoe on honda-tech)- still no spark.
7.I even have done this flashing test with 12V probe as described here, on page 5:
http://www.team-integra.net/sections/articles/showarticle.asp?ArticleID=1116- no flashing- so bad ICM but there is no flashing from a known good ICM either.
( I also have a problem understanding why the clip has to be on positive bat terminal… hmm , after checking the Helms manual, it would seem that ECU would pull the voltage to 0 so then it would flash… who knows… maybe… anyway, no flashing.- ECU is not pulling the voltage low on YEL/GRN wire. so could it be 2nd bad ECU? - checked all possible grounds, seems OK.
- checked the CPK, TDC, CYK sensor connections from distributor to ECU- all OK,
- no skipped teeth on cams and belt.
so far my car is dead. it turns (starter and battery is OK) but does not start.
At this point I have no clue how to continue and constructive input would be appreciated.
thanks in advance.
T.
