Someone is selling a brand new oem cap and rotor from a 98 DC for cheap so I was wondering if it’s compatable with the DA?
Cap #1002430102-p54-006
Rotor #1002430103-p08-003
wrong part numbers
30102-p54-006
30103-p08-003
im guessing you have an LS motor?
[QUOTE=tilegend;2026383]wrong part numbers
30102-p54-006
30103-p08-003
im guessing you have an LS motor?[/QUOTE]
That’s the part number the guy gave me for his cap and rotor. He owns a 98 integra and I own a 91 LS.
So I take it they are not compatable huh?
[QUOTE=hybrid90;2026434]That’s the part number the guy gave me for his cap and rotor. He owns a 98 integra and I own a 91 LS.
So I take it they are not compatable huh?[/QUOTE]
why don’t you do like the first person suggested and do your own research by comparing part numbers on that site listed? You could spend 3 minutes searching there and have your answer. Or you can continue to ask here and continue to wait hours or days…
I know the part numbers are not the same between 98 and 91 Integras but for some Honda/Acura parts from different vendors… eventhough the part numbers are listed differently, they could be the same exact parts… for example some springs for EF and DA’s
I was just asking for first hand experience to see if anyone actually tried it that’s all…
Bad example. Springs for DA’s and EF’s are different part numbers and are VERY different parts. They are NOT the same.
well if ur stock ob0 it wont work that 98 teg is obd 2 (idk if uve converted to obd1 yet)…even if uve converted to obd1 i still dont think caps between obd1 and 2 are interchangable
Thanks for all the suggestions… final conclusion… it doesn’t fit.
