like ill start my car early in the morning and it’ll start and putter, puttering below normal rev and then i turn car off then start it again it’ll putter a lil i hit the gas n rev it and its back to normal what do u think the problem is?
what octane gas are you using,? and also when was the last time you change your fuel fliter?
I did use mid grade forlike a year or two till i changed back to regular and my fuel filter was changed a few months ago so hollaback
yea try using regular, i had the same problem so ran the car to empty, flushed out the injectors and used regular and it was fine.
and also if problem still consist wires and plugs,and if problem still consist… :shrug:
