i see oil leaking on to my headers, it aorund where the headers touch the block, a gasket is there. its a 91 rs with 4-2-1 headers off of a gsr
(HEADER theres only 1) need more info any pics
kind of confused from what you said, but if oil is leaking onto the header then its probably the valve cover gasket.
tthey wont let me up load the pic
if its coming from ABOVE the header then its possibly the valve cover gasket… if its leaking FROm the header gasket area it could possibly be bad valve guide seals on the exhaust side(probably intake side is bad to) but for this to happen your header would probably have to have a leak to… any pics of exactly where its leaking from?
