ok I’m really dumb when it comes to anything like that I just want to be sure it is what it says it is…the code I’m getting is 3 short…so according to this>> http://www.g2ic.com/tegtips/engine/13.html it’s the MAP sensor…is that correct I’m just looking for an answer…Thanks!
correct
Moreover its the Electrical Part of te Map, not the Vacuum… so you need to replace it.
Thanks!
…that’s probably expensive as fuck ain’t it…
Just buy my used MAP sensor and you should be ok.
