hot alternator
hot alternator
    hot alternator
    My dash lights are all dim and car is dying,
    most likely its the alternator, so i decided to check it out after i got home but the alternator was really hot!!
    I know my alternator is bad, but is it normal for it to be hot liek that?
    I am planning to replace just the brushes, but if the alternator being hot is a bad thing, then i may need to get a new alternator.
    I bet the bearings are going bad causing a lot of extra friction. I believe I paid about $25 for mine.
      If the brushes are bad, you'll usually have a flickering or steady alternator light lit on the dash - usually at low rpms (assuming the light works - it should come on when you turn on the ignition before you start the car).
      If the voltage regulator is bad or you have bad grounds someplace, you won't have a warning light.
