Does anyone know an online source for a water pump (esp one that ships internationally) for 1stgen b16a (91xsi) ive finally got my new distributor…and the exact same day the waterpump decides to take a shit i really want to get this car running so any help would be great :mad:
Should be able to use any B series VTEC timing belt and water pump, but yes, that pump should work fine. Worst case, take the pump off and take it with you to compare to a new one.
Make sure you replace the timing belt at the same time, do NOT reuse the old one! If it’s got enough miles/kilometers that the pump died, the belt isn’t far behind. A new timing belt tensioner is a good idea too.
