Maybe someone has some insight on this before I tear my engine apart.
This morning I noticed on the highway that my car was exceptionally faster during acceleration. Just before I got exited the highway I pressed the accelerator about 50% while in 5th gear to change lanes, at this point I noticed a hesitation to accelerate.
Later tonight I noticed the Teggie was still faster than usual, and again I continously depressed the throttle about 50% or more in third, fourth, or fifth gear to notice a hesitation to accelerate. This also creates a faint shake in the motor. One time I did notice a little smoke. Revving her up to high RPM?s seems more powerful than usual?
I was thinking about doing the following:
Leak down test
Changing the spark plug wires (currently clean quality performance Sumitomos, but age unknown)
The ignition is less than a year old: Cap, rotor, NGK platinum?s
ECU codes: none
Other: She does spit a little blue smoke on cold days/cold starts, or after sitting all weekend (valve seals or ring?)
Miles: 179,500ish
I just assume to get a new motor or a V-Tec head…
Searches
http://www.g2ic.com/forums/showthread.php?t=100072&highlight=bog
http://www.g2ic.com/forums/showthread.php?t=92507&highlight=bog
http://www.g2ic.com/forums/showthread.php?t=95121&highlight=bog
