I managed to get the broken half of the radiator drain plug out. My problem is I cannot find a replacement at autozone or any other autoparts store that can match the exact threads and size. I tried that HELP! brand. There was a few Honda ones and tried to match the closest one to it but no luck. Its really frustrating. Anyone know of this part # ? Thanks
When mines broke I went to the junkyard and located a half size civic raditor and “borrow” the drain plug. It was the same size perfect fit. But the acura dealer should have a plug since its an OEM part.
Here you go also
http://www.autopartsworld.com/1991_acura_integra-1-8rs-ls-3dr_radiator-drain-plug_parts.html
Thanks for your help.
just go to home depot or something and find a bolt with the same thread pitch and size. get a washer and some of that white pipe tape (forgot what its called).
Teg_Fury…
How did you get the broken part of the drain plug out of your radiator. I have the same problem right now.
Thanks!
